Old 06-17-2019, 05:48 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
I think the screw on the ORANGE wire's terminal to the fuse block was loose. The added resistance of the poor connection created the heat that caused the melted insulation on the wire to fuse #3 that was touching it. That ORANGE wire runs directly to the alternator, so it had plenty of unfused amperage to cause that little melting problem.
Yes, that could be the case, if the terminal was loose.
I think the 90 degree tags invite wires leaning on each, versus a straight terminal lug which would have no wires leaning on a hard uninsulated tag.
Gary
