Thread: Mega Squirt
Old 06-20-2019, 07:51 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by eschaider View Post
Yes but you will need to run it in speed density mode because there is no easy way to use a MAF w/o fabricating an air box that feeds all eight stacks from a common inlet plenum.
Absent the common feed plenum I believe the original Weber equipped cars used a copper tubing sort of interconnect between the bottom side of all the inlet ports to mitigate some of the IR pulsations that play havoc with the fueling of the engine. I don't know how effective the 'fix' was in real life. Perhaps some of the Weber crowd could chime in with their experiences.
Ed
It worked very well.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
