Originally Posted by vntgspd
I specifically sourced and used PCV hose so he didn't say anything. I would suggest replacing the braided lines with rubber PCV hose so you don't waste your time in the event your inspector is diligent. You can probably just slip the hose over the AN fitting for your braided line and clamp it down. It's a visual test, not a performance test.
Bring ALL of your documents, and you should be good. If you were missing anything, they would have noted it at DMV or CHP. But, my inspector wanted to review the docs for their file as well.
Awesome. I have some Mishimoto MMHOSE with PCV stamped on them, and I have an original Ford PCV hose that goes from the valve cover to the air filter. I can always put the braided hose back after.
