Originally Posted by Texasdoc
As per AFR's instructions - 55 ft/lbs.
I'm tempted to try a stud girdle. I like the shaft rocker systems but $1300-2000 seems kinda steep. I upgraded to the 7/16 diameter studs and I don't twist it above 6000 rpm on my .600 lift cam. So I shouldn't NEED a girdle.
No, probably don't
Need a girdle.
I had trouble keeping the lock nuts in placed. I tried every kind of lock nut on the market, but they still worked loose and caused mayhem. A stud girdle fixed all of that.
