Old 06-25-2019, 01:33 PM
patrickt patrickt is offline
Originally Posted by Large Arbor View Post
10-4. Mine seems like it has 1/4 inch of play in it when I pull on it which is more than the other side. Given that is there a shim that would tighten it up?
Phil
A quarter inch of hub end float is a huge, huge, huge amount. Are you sure that when you pull on the wheel you're not being fooled and it's really coming from the u-joints and fulcrum area and maybe the differential output shafts, maybe all added together? Setting the HEF is pretty straight forward, albeit a serious PITA. Shorty instructions can be found here: Setting the Hub Carrier axle bearings but I honestly don't think you have a quarter inch of HEF.
