  #492 (permalink)
Old 06-26-2019, 04:58 AM
1795's Avatar
1795 1795 is offline
Originally Posted by xb-60 View Post
Jim, your water temp gauge reading appears to be low....is that a correct reading at between 120 to 160? You mention that it "Did not boil out as much water the last race"?
Great footage to watch for us armchair spectators! Aside from the ever present risk of bingles, as well as the long lonely nights in prep for the races, you must be having a ball on the track!
Here's cheers!!
Glen
Glen,
With the FIA fuel log there is no port for the water temp sensor. Tried to find a place with adequate metal to place a bung but could not find one. Had the engine builder make an in-line assembly, but there was no room to place it between the intake and radiator, as that is where the thermostat had to go. So, the only place left was in the line coming from the radiator back in to the engine. I did notice that once the thermostat opened that the temp went from 180 down to 140, so I am going with adding 40 degrees to the water temp to estimate engine temp. Not optimum, but it is what I am stuck with until I can find a better place for it.
Jim
