Old 06-26-2019, 08:57 AM
cycleguy55's Avatar
Originally Posted by spdbrake View Post
From what you described, I think your saying the pedals are closer (less free-play) to you once the car is warmed up. If so I'd suspect water. You may also take a look at the line routing around the headers and if you can add a heat shield below the master cylinders. If - like most Cobra the headers are less than a foot away.
The next to last paragraph in this article describes the pedal issue.
https://www.good-guys.com/hotnews/te...d-brake-fluid/
So, DOT 4 can replace DOT 3, and DOT 5.1 can replace both DOT 3 and DOT 4. It seems like the prudent thing to do for our cars is use DOT 5.1 not just because it's 'the latest and greatest', but primarily because it has the highest wet boiling point and is also the least likely to absorb water - at least among the 'cross-compatible' types of fluid.
As noted elsewhere, most people would be well advised to avoid DOT 5.
Edit: I note Summit Racing has numerous types of DOT 3 and DOT 4 from which to choose, but only 3 listings for DOT 5.1 fluid. Limited selection, but at least it's reasonably priced so we don't have to give up our first born - though there are times we might want to do just that... LOL
Brian
