Old 06-27-2019, 06:47 AM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
Also make sure the the push rod is loose on the master cylinder when you release. Any pressure at all. and the compensating port will be covered in the master cylinder and it won't allow the fluid to go back into the reservoir. therefore building up pressure before you push the pedal. JD
