Originally Posted by Gaz64
Were any of the 3 slave cylinders leaking?
With any clutch issue, if a slave cylinder is not leaking, it is not the cause of the fluid loss, then you move on to checking the rear of the master cylinder.
Gary
AS Patrick would say it was part of my learning curve .Some curves are longer than others.
