Originally Posted by Jdata
What size brakes are you using? And also what type meaning material
I have 13" front rotors with Baer 6 pot calipers and 12" rear rotors with Wilwood 4 pot calipers. I wish I had gone right to Brembo calipers but hind site now. I have tried lots of different compounds from Wilwood, Carbo tech and others, currently use a Porterfield compound. The master cylinders are AP with a 7/8" front and 3/4" rear and adjustable bias bar. Brake modulation is good just too easy to lock. I just took 1 degree of camber out of both the front and rear this week. Hopefully decel will be better now. Rotors are very high grade Stop Tech front and Wilwood's best in rear. Front pads are Corvette size so tons of material choices rears Wilwood so not as many choices. Bigger rotors just add rotating inertia so that is not the answer either maybe ceramic.
