07-21-2019, 05:31 AM
AR
[quote=kevins2;1464562]As Olddog indicated, the symptoms could be any number of things. The coil would be high on my list of things to check out.[/QUOTE
Agree with Kevin - coils going bad will work fine on a cold start up and when they warm up then start failing. Let them cool off and they will work OK until hot again. Eventually they just go kaput. If that is the pattern you are seeing then trying a different coil is a good idea.
