Old 07-21-2019, 12:33 PM
Grey 65's Avatar
Grey 65 Grey 65 is offline
Cobra Make, Engine: BDR #888, Keith Craft 408
Car is fine being jacked as shown in the photo. Avg BDR will weigh in at about 2,650lbs wet with a 57% rear weight bias. Those outer bars are more than capable of supporting 700lbs at each point.
This being said when I jack car up at home I use inner rails at 4 jacking points. When I jack a side of the car up at the track I use outer rail 1 jacking point.
In conclusion, I have probably jacked my BDR up using 1 jacking point on outer rail than you will ever do using double the jacking points... i.e. it is fine to use outer rails.
Kevin......
It isn't how fast your car can go
It is how fast your car can change direction
Home of Fake Snake Racing
