Hi All,
Im selling my original hardtop. I have offloaded the mold, but before I did took one last copy to make myself another (that Im modifying a bit) and no longer need the original.
This was one of the original tops Gav, Phil and I got from Bruce Chervanak (Mr Bruce) many years ago. Modified and fitted to a Classic revival. For CR owners, my windscreen measurement is 1035 from the outer edge of screen to the top of the tunnel at rear bulkhead.
Will come with side windows (6mm plexi that attach to the wind wing hinges – hinges not included) all pinch weld around windows, hatch and where body meets the top, rear window, t bolts for windscreen, handle and latch fittings etc. Does not include body ferrules. Read back through this thread for details.
Finished in my classic cement paint scheme – would just need a block sand prime and paint to finish off to match your car. Like most projects, I never fully finished it to the final standard as I always seemed to run out of time before a nationals (and then never revisit). I will include an additional hatch outer skin (in gelcoat) if you want to modify the hatch setup - if I was doing it again I would dispense with the steel frame and just glass in some core mat for extra strength.
FAQ's - No I wont fit it to your car - your welcome to come and try it on for size though.
Looking for $2000 ono.
