Mcleod. Uses rings on the retainer to adjust. The movement is only about .4something so it can't be too far out of adjustment. If the pedal comes to an abrupt and hard stop and the clutch is still not releasing either your pedal needs adjustment or the bearing is limiting movement, in that case do not use the Hulk leg. Adjust. If your clutch is slipping, adjust. It appears yours has one large spacer and a short one. Mine used multiple shorter ones.
Don't think they make them anymore.
