AC MKIV Shock/Ride Height problem
Several years ago I replaced the shocks on my MKIV since the old ones were leaking. I used Spax G953 on the front and G952 on the rear and reused the orginal springs. The spring adjustment ring is as low as it will go but the ride height is still 1-2" too high on three corners and 2-3" on the right front. Any suggestions on how to fix this problem? The only thing I can think of is cutting and removing a coil from the springs.
