  #139 (permalink)
Old 08-05-2019, 09:25 PM
xb-60's Avatar
xb-60 xb-60 is offline
Hi Tim,
Thanks for the comments. My dash is coming along quite nicely, and the glovebox has turned out as well as I'd hoped (and better than I'd expected ).
When I think of the originally supplied ABS flat bottomed dash panel, described as a "drop-centre dash".....
Here's the requested "glove" shot....
Quite amusingly, the glovebox strap I ended up with was the fourth iteration .
What's next? I'll be moving on to populating the dash as much as I can. Access to the rear of the dash is quite good, so not anticipating that to cause me excessive delays by doing that. After that, probably had better start under the hood. There's a lot of work to do there with sheet aluminium and also stainless sheet and insulation....and of course some work on the firewall.
Cheers!
Glen
