Old 08-12-2019, 04:40 AM
stephen low's Avatar
stephen low stephen low is offline
Default Motec, sensors and coils help
Guys
Am seriously thinking of getting the Motec I have had in storage fitted finally.
Some early research I did ages ago included conversation on the Motec page.
Got this response below from a Motec staff member, and want to try and confirm what my AU windsor engine may or may not have so I can prepare for the ECU and wiring change over and install.
Motec feedback as:
"The basic sensors needed to run an engine using an M84 are as follows;
Crank trigger position sensor
Cam (Sync) position sensor
Throttle Position Sensor
Manifold Absolute Pressure Sensor
Engine Coolant Temperature
Inlet Air Temperature Sensor
These should all (IAT is potentially in the MAF sensor) be currently present on the engine as they are the standard inputs for any EFI system, and can be used with the M84 by calibrating the sensor inputs to the M84.
With the coils, they may need to have an external igniter, but most modern coils have built in igniters. How many wires go into the coils? What is the part number of the coils? With that information I should be able to tell you if they need an external igniter or not."
Not all quite Greek to me but am more to happily say I am just not sure what my engine does and doesn't have.
So from the collective experience and exposure with the AU windsors, can anyone provide definitive advice on what my engine should have compared to the list above and including coil capabilities?
Hope sonebody can help.
Steve
slowy
