Originally Posted by my427cobra
Thanks Dominik. Great info.
But I'm not sure what you did here:
"Assuming 5" ground clearance, then your differential/axle shaft outlet is 5" + 2" + 5.25" above ground = 12.25""
I understand hat 5" is the ground clearance.
What is the 2" and 5.25"?
You're probably wondering what the heck I'm up to.
I'm going down the path that Tom started in a previous posting to use a Corvette C3 differential in a 427 Cobra chassis.
My car is a replica and I am scratch building an IRS for it (just because I like doing that stuff) and wanted help confirming the dimensions.
Another question though.
The Cobra uprights appear to have some castor built in to the UCA mount, but a heim (spherical) joint up there would probably wipe out any castor.
What castor does the 427 Cobra rear upright run at?
I'm about 3/4s done the mock up of the IRS and should have it done in a couple of weeks.
Thanks again for all your help.
Greg
The addition of: 5" (ground clearance) + 2" (from center of chassis) + 5.25" (to diff / axle shaft center) above ground = 12.25"" is the position from ground of the center of your axle shaft as they are coming out of the differential.
Makes sense? This is from the Cobra Restorers drawings.
Kirkham once posted their ground clearance, which you may want to find and use. Else the 5" shouldn't be far off.
I am still struggling to log in, but I am sure you won't be stranded without my input :-)
On a side note:
Looking from above your rear upright will turn/twist during suspension movement. This is to help corner entry and exit.
Racing Cobras have this eliminated. Their suspension movement is limited and this "bump steer(!)" has no noticeable effect.
It is mandatory to keep it at bay for a street car. Not so much the bump steer itself, which you can't really change, but the static toe setting at ride height. And for this your ride height must be correct...
Did I hear Tom's Motorsport in Vegas who set up Cobras since ever? Look them up?
Or find "Morris" here. He has two brains when it comes to Cobras!
