  #29 (permalink)
Old 08-23-2019, 12:06 PM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by bcrumpley View Post
Thanks Dan. I am going with the extended track option with sunbursts, so maybe it will work. Sounds like I better get on the ball about that decision because I'm about to start the differential build.
It would seem that as long as the pipe go around the opening into the wheel wells for the differential/half shaft tunnel - it would almost have to clear the suspension arms. But you might ask Doug - could be something with the outer hub/disc brake caliper mounting that interferes.
ERA 782 Running
