Old 08-27-2019, 06:40 PM
PaulProe's Avatar
PaulProe PaulProe is offline
Cobra Make, Engine: Hurricane - FE
Originally Posted by Gaz64 View Post
Paul,
While this very loud noise in neutral is there, can you depress the clutch pedal a small amount, and see if the noise changes?
Gary
Gary
As soon as the clutch begins to move, the squeal quits.
If it were a throw-out bearing, would it not also squeal when released and in a given gear? This only does it in neutral or as the shift pattern moves thru neutral.
Paul
www.65shlb.com
www.prdcrrct.com
