					Originally Posted by  kevins2
				Thanks Patrick, I assumed I'd need to fabricate my own bracket and you just confirmed what I thought I was seeing in that a lot of the differences were simply the mounting bracket.  Both of you have ports on opposite sides (180 degrees) and one straight fitting and one 90 degree fitting, which would also work for me.  It appears that most of them come with 90 degree fittings.  I see the Miata versions have one of each...  Interesting way to decide on a specific part!
Kevin
 It's like going to PepBoys and asking the guy at the counter if you can just go in the back and rummage through the hoses until you find one you think you can trim to fit between your water pump and radiator.
