Old 09-02-2019, 08:11 AM
patrickt patrickt is offline
Originally Posted by steve meltzer View Post
Stock Holley (4160). In your prayer books, oops I mean the Holley factory instruction sheet, they show TWO nozzle gaskets (ref #117), but I thought i heard that you should only use one. The deepest one. Do you use one or two between the nozzle? I could be hallucinating again. thanx steve
You use both, but they do not touch one another, they go on each side of the nozzle. So, that means: Pump Discharge Nozzle Screw, Gasket, Pump Discharge Nozzle, Gasket... in that order. NOT two gaskets smushed together because two gaskets are better/fatter/nicer than one.
