Old 09-02-2019, 05:09 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
You use both, but they do not touch one another, they go on each side of the nozzle. So, that means: Pump Discharge Nozzle Screw, Gasket, Pump Discharge Nozzle, Gasket... in that order. NOT two gaskets smushed together because two gaskets are better/fatter/nicer than one.
Yes, two gaskets Steve, one above and one below the nozzle, as Patrick has said.
A little harder to do on the primary side with a choke plate in the way, but easy enough once you have done it a few times.
Screw, gasket, nozzle, grease, gasket.
Gary
