Old 09-09-2019, 06:04 PM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Spent the day on the harness, took the rear section completely out of the loom and checked for possible shorts. Found a trouble area between 2 wires and fixed it.
Now, all the turn signals work correctly, except when the headlights are on.
They work correctly with the park lights on. Anyone have any ideas as to what's causing this?
Brake lights still are now working. I haven't tried them with the headlights on or with turn signals.
The only thing left is the turn signals working with the headlights on. The turn signal indicators will work for awhile with the headlights on, then they quit working. The turn signals will work for awhile (very slowly).
Edit: I'm told that this is a classic ground problem -- I thought I had the ground problems solved. Will recheck and redo them tomorrow.
Thanks,
Jim
