Old 09-09-2019, 11:13 PM
Cruisin428 Cruisin428 is offline
Cobra Make, Engine: FFR 347
Unplug the headlights and make sure you have the same issue with the turn signals, with the head light switch on running lights and then with head lights on (but no bulbs). See if they will work longer than before!
The install sheet helps a little, unfortunatly, it leaves out what the switches are actually doing, it makes sence, you would need to look up the actual wiring for the switches to start putting the whole "picture" together! Hopefully its simple and you find your ground problem!
