Originally Posted by caesarmascetti
for what it's worth from everything Ive read you dont need an airgap, the current Preformer RPM works just as well and offers more clearance. I would add a spacer between the carb and intake a phenolic spacer (keeps the carb insulated from heat). As for a carb, Quickfuel VS 750
my two cents
interesting read
https://www.hotrod.com/articles/hrdp...pm-vs-air-gap/
Hot Rod did not test at operating temperatures, in other words not real world application. They stated they did not data log temps.
Both manifolds on a cold engine would have similar numbers. However as the engines get to full operating temp, the air gap should deliver a cooler fuel charge. I would not save the $28.
