Today I ran even more grounds hoping to solve the problem that Autowire talked about.
I'm pretty sure the car is now completely grounded -- ran new wires from the ground bus wires to each headlight.
Didn't work.
Disconnected the headlight bulbs, and the turn signals worked with the headlight switch in the headlights position. Thought it might be the bulbs, swapped them for some old ones I had, the old bulbs worked on high and low beam but the turn signals still won't work with the headlights on using the other bulbs.
I am at a complete loss as what to do next, but will try replacing the headlight plugs, I have a new unused pair -- will try them tomorrow and will test run each ground wire on the plugs directly to the negative post on the battery which should eliminate any ground problems.
Thanks,
Jim
