Old 09-13-2019, 07:59 PM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Tried the GM headlight switch -- no difference. Went back to the Speedway switch.
Took the turn signal switch connectors apart, and the wires run to them -- didn't see anything wrong.
Had a idea this morning, went out and bought another turn signal switch and hooked it up without installing it in the column. The turn signals started working with the headlights on and the indicators plus everything else started working correctly.
Even though I had already replaced the turn signal switch once, I either ruined it or the switch was bad. In any case, the new replacement turn signal switch cured the problems.
Thanks,
Jim
