09-14-2019, 09:10 AM
Ca
Cobra Make, Engine: Superformance , Roush 427SR dyno'd at 526 hp
Originally Posted by bobinyelm
Just got my car together, and installed the engine with a "standard" Wix oil filter already on it.
I didn't notice until after the engine was in that there is only 1/2" clearance between the end of the filter case and the chassis.
I doubt I will be even able to remove the filter when the time comes, much less get a new one on there.
Obviously, I can Sawzall the end off the present one and remove it in two (very messy) pieces, but is there a shorter filter that will work w/ the engine with the proper relief valve or anti-flow-back valve as the OEM filter possibly has?
I was planning to install an oil cooler via an adapter under the filter, but cannot imagine even w/ a shorter filter there would be room.
Is everyone running a remote oil filter, or just a shorter one?
Thanks,
Bob
I am running an Oberg filter on my Roush 427 (351 stroked to 427) I replaced the dual filters that were on the car. Picked up 25 psi more. Works great and is easily cleaned and is re useable. Check out their website.
