Do you have a brake booster. I would need 2 feet to be able to lock up mine. As my engineer said, if you need 40 pounds of foot pressure to stop then you can regulate your brakes with more precision. Modern cars before ABS you could lock up the brakes using your little toe, therefore much harder to avoid lock up. Obviously locking up slows you a lot less then keeping your wheels turning.JD
