Old 09-20-2019, 05:10 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by twobjshelbys View Post
Alot of this is not correct if you have a capactive discharge electronic ignition, like a MSD box. If you do check the book on how to measure spark.
Keith's specs seem unlikely to have MSD CDI ignition, so Perrys statement of 12v on the coil positive, and interrupted ground on coil negative would be true in this case. Normal for any inductive spark ignition.
Gary
