09-20-2019, 12:23 PM
SK
Ford EEC-IV/TFI-IV Electronic Engine Control Troubleshooting
https://therangerstation.com/tech_li...agnostic.shtml
Fords Without a Check Engine Light - Start the vehicle and let the engine warm. Then, turn the engine off. [Note: yes, I'm aware the car won't run. Obviously you will have to skip this step.]
- Set the volt meter to read between 0 and 15 DC volts. Connect your volt meter's positive lead to the postive terminal on the Ford's battery. Then, connect negative lead to the self test outlet's grounding slot.
- Connect the self test outlet's signal return slot to the self test input with a jumper wire.
- Turn the Ford "On," but do not start the engine. Count the times the needle sweeps. There will be a small pause between numbers within the code. Code 14, for example, will have one needle sweep, followed by a pause and then four more needle sweeps. Long pauses indicate the beginning and end of a new trouble code.
http://diagnosecarproblems.blogspot....rd-eec-iv.html
Brian
