Old 09-27-2019, 11:51 PM
Manx69 Manx69 is offline
So here’s the story. There is a circuit board on which are mounted all of the fuses and some relays. The terminal at the top fuse is where a black wire goes to the red and green wire in the engine wiring harness. The terminal failed. The next fused terminal below it was also switched off of the ignition and empty. Simply moved the wire and fuse down to that terminal. I have no clue as to what caused the failure.
I verified power through the ignition switch but was not sure which specific wire went to the coil and relay wire in the engine harness. Found it after lots of continuity checks in various parts of the under-hood and under-dash rats nests until I located it and traced it back to the circuit board. This was a very miserable and time consuming job. Many hours of uncomfortable troubleshooting and the such a simple fix. All is now well. Thanks to all who gave advice.
