Tires rubbing on front inner well well.
Hi all, I'm having an issue with front tires rubbing on the underside of the wheel well close to the outer lip when going over small bumps in the road way. Has anyone experienced this on their A&C Auto Cobra builds? As I am aware I'm the first builder to install a Ford Coyote 5.0L into A&C Auto's Cobra. This engine is 450 lbs which maybe 200 lbs lighter than a FE or 302/351 engine. The front coil over's that came with my kit have springs that are rated at 250 lbs, not sure if the rating is high enough for this application. To get the right ride height the coil over's are adjusted as far as they can go. Any help would be extremely appreciated.
