The distributor has a Jegs part number, but I believe in using what you have, so I'll continue using it no matter who made it.
I did notice that after I charged the battery the spark looked hotter.
I was just about ready to pull the water pump, drop the pan and take off the timing cover and check the timing marks --- but thought I'd give it one more shot first at trying to reset the distributor.
What I did was pull the #1 plug and put my finger in the spark plug hole, turned it over until I felt compression -- then turned the motor over until it hit TDC. After that, I got the distributor pointed at #1, and it just fell right in place. Thought for sure I had it,
and it's trying hard to start if the distributor is rotated to the right.
I was hoping someone could tell me the best way to get it to where it will start.
Thanks,
Jim
