  #28 (permalink)
Old 10-06-2019, 09:58 AM
olddog olddog is offline
Run a compression check on all cylinders. That's easier than pulling the timing cover.
As someone before me suggested, the valves may be too tight, or a few could be stuck.
If you have good compression, the cam to crank timing is likely close enough to run, and the valves should be loose enough to start.
