You just need to ensure the belts have a free flowing unrestricted run, with the inertia reel unit perfectly vertical. Otherwise they catch and/or don't retract properly. You can add spacers, etc, to optimise the routing and reduce acute angles.
If the spring is worn in the inertia reel unit, then you can replace the entire 3-point assembly with good quality new kit, easily available from the likes of Securon, etc.
I prefer a 4 or 6 point harness, but it's not the most convenient option.
