ABS Test
We ran at Crows landing today, first off we did a manual brake bleed then a system power brake bleed with my laptop connected to the Bosch unit. After doing that we turned the ABS off and adjusted the brake bias to get a simultaneous lock up. I had Scott turn on the ABS and try some stops in the 60 mph range. The car pulled 1.2 G which is better than we have ever gotten prior to ABS on 200 TW tires. We ran the test course to break in a new set of Bridgestone RE71's and the brakes worked flawlessly. Scott says it feels better and more controllable than the GT3! The unit has 11 settings from 1 to 11 with 11 being the most aggressive we had it set on 2. It will be fun to try the other settings as we learn the system. I think this takes the car to the next level but won't know till we run it in competition in November.
