Thread: motors
Old 10-19-2019, 08:41 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Depends on the camshaft type (roller or flat tappet), lifter type (hydraulic or solid), bearing manufacturer etc.
Oil pump driven gear type (on distributor) and inspection is also a factor.
Carbon buildup, ring gaps increasing, bores wearing etc add up to efficiency loss.
When you feel the power is down a bit, a "freshen up" is probably due.
Gary
