Thread: opinions needed
Old 10-20-2019, 09:49 AM
olddog olddog is offline
If you want accuracy or flexibility to change gears and tires, with easy correction, then go digital.
If you want to stay true to the 1960's, stay with the cable. I think you already blue that, when you installed the TKO. You would at least have to have an FE for this to bother you in the least.
PS
Does an aluminum 482 stroker count as an FE? Well it sure is a modern improved FE, to me. So you tell us, does nostalgia bother you, when you use more modern improved parts?
