Originally Posted by hauss
Maybe I should explain better, what I meant was hitting the 6500 rpm, but only for a second or two. Mostly 3000 to 4500. Motor seems to love 3000 rpm, that is it"s sweet spot to run all day.
Well, then that is a whole different story. An occasional helps clean out the cobwebs and is not of a major concern as long as you are checking the engine on a regular basis. It's the extended time at high rpms that starts to wear an engine down. Running at about 3,000 rpms is a nice range.
