Bob:
I took my entire brake assembmly to Taylor Racing in Dallas. Craig Taylor determined the problem was the Master Cylinder for the rear brakes (the rear calipers were in bad shape, so I also replaced them). After replacing, I am having trouble bleeding. Tilton requires you bleed the right side together, then the left, which I did. The pedal was still soft. I then used a vacuum device, which did not help. I even went back and bled the Master Cylinder's again. The Hydraulic Emergency Brake is set up on the front brakes. I loosened the line going out, thinking air could be trapped. The pedal is still soft.
Have I missed anything? I've been at this for hours!
THANKS!
