Hi Guys...
I have a ford falcon and considered installing the solonoid operated inline rear brake / emergency brake system so my wife did not have to use the old handset for the emergency brakes. Just compress the pedal, push the button and it engages. As I studied the system I found that the following problems may become evident:
1. Drive the car in the morning...say to work and set the brake. When you get back into the car at the end of the day and try to press the brake pedal to disengage the system... the heat difference outside will cause the fluid to build pressure and you will have lockup of the solonoid and you end up having to loosen the brake valve to release some pressure. Not what your wife wants to do in the parking lot after work.
2. The solonoid will sometimes stick and not let all of the pressure back off when you press and then release the brake pedal.
I decided to install the foot operated brake system. Also, the State of Calif. requires that the emergency brake be mechanical instead of hydralic. All this info came from a major brake distributor in West Sac. I assume it is correct, but there may be allowances for the e. brake unit.
Om this same subject... I am looking for a company that builds the e.brake system that bolts to the driveshaft/rear end housing. Anybody have any info on these?
Thanks, Mark
Tinman
