You should also dimension the center-points for all the corner radius’s, trying to line up two edges of the bit will cause many errors....
The sides could be a separate piece from the horizontal sheet too. Bending could be difficult as the sides do not appear to be 90 degrees to the base?
You could make a test on plexiglass sheet first....
Blas
SPFWiringDiagrams@Comcast.net
