Door hinge cover or guards
My EM had padding and duct tape covering the two parallel tubes that are what you see of the door hinges, and end up having your leg against. After 35 years the duct tape is worn and needs replacing. My Drivers side also had a semi ridged foam block covered with black vinyl material and then double sided adhesive taped to the door panel for my thigh to rest and brace against. Any body have any treatments for these points? How about the door hinge limit straps and the door latch pull straps? What did you do or what have you seen?
Mike H
