Old 11-17-2019, 07:55 AM
wolf k's Avatar
wolf k wolf k is offline
Cobra Make, Engine: Sold ERA FIA 2139, 331 Weber IDF
Default Lucas dash switch failure, carry a jumper wire
Turned on my fuel pump switch the other day, movement felt weird, and pump would not energize. Luckily I was at home in my warm, toasty garage.
Normally I don't carry emergency supplies, but now I will as car is getting up in age.
Took switch apart and this is what I found, tiny, cheesey plastic pieces.
Failure piece is in bottom photo. That little plastic cup goes between the metal ball at the end of the switch and the spring which pushes on the rocker contacts.
That cup broke, thereby not allowing any tension on spring, thereby not able to push on rocker contacts.
