Originally Posted by RockBit
I didn't check ERA's wiring of the plugs but fortunately did not have any problems there. Be careful when you add the block connector to the rear wiring in the drivers footbox. I somehow wired mine as a mirror image of what it should have been, and every time I turned the key to on I blew a fuse. I figured out what was happening and rewired the connector correctly, then all was good.
After I installed the dash and plugged everything together, I had Sheila zip tie all the wiring in place (she is smaller than me). I don't know what she tied things to, but nothing is visible!
I have been lying under dashes many times, and that contributed to my lower back injury, so please be careful.
I also like your instrument layout, all in easy view for the driver.
Gary
