Old 12-05-2019, 05:43 PM
Mongoose930's Avatar
Mongoose930 Mongoose930 is offline
Cobra Make, Engine: Hi-Tech
Thank you all for your responses. I think the unique challenge that I have right now is the Lemans Bowls. I am certainly no carb expert, but if I can't get enough fuel into the bowls to start with, then nothing else downstream will work. So far the viton tip needles I have found are pretty small -.092 orifice and the larger size needles are steel - .128. I ordered a set of the Daytona float needles today and I think I will give them a try. I am hoping that by replacing the needles, setting the floats and changing the jets to a more appropriate size for my engine, that it will run even better in the spring. I will keep you posted on my progress.
