Thanks Pat, done....
One more question, I was surprised to find a plug in the line going from the pcv valve in the intake manifold to the bottom of the carburetor. Someone must have thought it was causing
oil consumption, but the real cause was a bad intake gasket. Should I remove the plug while I’m in here or is it better to have the pcv valve functional? No sense drilling the turkey pan to run it if it’s plugged anyways.
