Old 12-16-2019, 10:16 AM
tortuga tortuga is offline
Default One last experiment:
1. Ive got one of those motor puller plates that i will bolt down and seal with some rubber to the intake with the carb off,
2. pop the valve covers and release all the intake valve rockers closing all the intake valves, compression was good so i assume these seal,
3. Put a vacuum pump on my brake vac line, with the PCV line plugged (both come off the manifold just below the carb (trick flow R single plane).
Apply vacuum and listen/observe...any really leaky guides should make noise? Should also check for sealed intake manifold gaskets?
Anybody ever tried this or something similar? I would think it will determine if there is a problem topside or with the rings?
I just hate the idea of pulling the engine for logistical/working space/help reasons...Heads no problem.
Steve H
Superformance 1764
Built 427W
Aiken SC USA
